February 9, 2014, 05:24 |
Under prediction of Forces
Gaurav
Rep Power: 12 |
Hi, I am simulating a INSEAN E779A propeller using Fluent. I have created unstructured mesh in ICEM. My problem is I am getting very low value of thrust compared to experimental results? Can anyone suggest the reason for that?
Thanks Gaurav |
February 10, 2014, 09:47 |
Jon
Rep Power: 13 |
First things first.
I would check and double check the angular velocity of the blade, density of the fluid and your geometry...happy digging. |
February 10, 2014, 10:25 |
Under prediction of forces
Gaurav
Rep Power: 12 |
I have provided the fluid with rotating reference frame. So I need not to give angular velocity to blade. Density of water is 1000 kg/m^3, that I have checked, that is not much different from experiment.
February 12, 2014, 05:04 |
Rep Power: 143 |
how to get forces on Iso-Clip Surfaces and How to get forces in cylindrical coordinat | CFD XUE | FLUENT | 3 | March 18, 2015 03:28 |
Forces for airfoil test case | Martin_ | OpenFOAM Running, Solving & CFD | 1 | July 2, 2012 11:58 |
forces in interFoam | Svensson | OpenFOAM Post-Processing | 2 | May 9, 2012 13:31 |
FORCES don't run! | C12Carbon | OpenFOAM | 0 | September 10, 2011 07:34 |
Valve Forces in CFdesign | Mike Clapp | Main CFD Forum | 3 | March 8, 2001 14:09 |
