February 13, 2007, 06:27 |
The entropy function
hi, could some one tell me what an entropy function is.. and also give a bit of physical insight with examples? and how does one know whether an entropy fix is required for a numerical scheme? thanking you
February 13, 2007, 21:19 |
Re: The entropy function
The entropy fix has been there for a long time.The computational fluid mechanics and heat transfer book of pletcher et al provides detailed information on when it is needed.
February 14, 2007, 18:12 |
You've got the answer for the first part of the question in my previous reply. To find out if the Riemann solver needs an entropy fix, all solutions must be examined to see if there are any unphysical solutions admitted by the formulation. Expansion shock is a famous non-physical solution admitted by Euler equations.
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
