Best code for Cd calculations?
Old   February 28, 2007, 14:43
Default Best code for Cd calculations?
HSeldon
Hi, I´m dealing with 2d airfoils with and without flaps and slats. Fluent doesn´t give me good results regarding the drag coeff, so I would like to know about your experiences about that, and wich code is the best to get that number.
Thanks!
Old   March 1, 2007, 19:47
Default Re: Best code for Cd calculations?
buch
The drag computation relies on many aspects. The computed properties of your boundary layers will have such an impact on your results that I do not think changing software will really be a solution.
Try other meshes (with points enough in the BL, and a correct first grid cell size in the wall-normal direction), and other turbulence models.
Anyway, for complex flows such as airfoils with high-lift devices, I have seen some papers for which the drag value on each element (for example on a 3 elements airfoil) was quite wrong, but with error compensation the overall drag value was quite ok ... Scaring.
Regards
Old   March 1, 2007, 19:52
HSeldon
Hi buch, Yes, I tried all what you said (all kind of meshes, different turb models, etc) Right now I´m using Fluent, and I heard that others codes use differents approaches to calculate the Cd with better results than Fluent.
I´ll keep trying! Thanks
Old   March 3, 2007, 09:21
Charles
Have you tried MSES?
Old   March 3, 2007, 22:34
HSeldon
Nope, I didn´t. Do you know if they have a demo or something like that?
Old   March 4, 2007, 01:24
Charles
I don't know. You will have to ask Analytical Methods (http://www.am-inc.com/MSES.shtml) What I do know is that the code is not cheap (US$ 10 000?) , but it is a dedicated method for designing and analysing multi-element 2D sections, even with some transonic flow. As such it is mighty quick, and, from what I've seen, very accurate. Importantly, it uses the same laminar/turbulent transition method as used in XFoil.
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 12:30
Debugging Unsteady 2-D Panel Method Code: Wake Modeling RajeshAero Main CFD Forum 5 November 10, 2011 05:48
Open Source Vs Commercial Software MechE OpenFOAM 28 May 16, 2011 11:02
Small 3-D code Zdravko Stojanovic Main CFD Forum 2 July 19, 2010 10:11
Understanding k-omega SST model source code tmhonka OpenFOAM Programming & Development 1 September 8, 2009 07:33
