July 20, 2009, 12:06 |
SIMPLE algorithm, P and u at inlet
Rep Power: 17 |
Hello everybody,
I'm solving the N-S equations using the SIMPLE algorithm. It converge fine and quite fast when I set dirichlet boundary conditions for the velocity at inlet and outlet of the channel, but I have problems when I want to set dirichlet B.C. for both pressure and velocity at the channel inlet. I'm solving the u-momentum equation at the main control volume interfaces, and the pressure correction equation at the central nodes. how should I set the pressure value on the first node, in order to fulfill the inlet pressure condition? I think the problem is there. thanks in advance Mauri |
channel flux, n-s, simple |
Finite Volume -- SIMPLE Algorithm | Roger | Main CFD Forum | 9 | September 25, 2023 12:04 |
Limits of SIMPLE algorithm | Benzaa | Main CFD Forum | 1 | June 10, 2009 11:42 |
SIMPLE algorithm for variable density flow | mauz | Main CFD Forum | 1 | May 15, 2009 15:13 |
sample MAPLE code for SIMPLE algorithm | mia | Main CFD Forum | 0 | February 27, 2009 23:22 |
Inlet table in STAR-CD | Sachin | Siemens | 1 | March 26, 2008 10:22 |
