Negative propulsive efficiency of a moving airfoil
Old   March 3, 2007, 06:09
Default Negative propulsive efficiency of a moving airfoil
zonexo
I'm doing my simulation on moving airfoil. I found that for some configuration, I got negative propulsive efficiency. Is that possible?
Power input is defined as the energy required to move the airfoil. I've got a positive value.
Power output is defined as Thrust * free flow velocity. In these cases, drag was mostly generated instead of thrust, hence resulting in the average Power output over 1 cycle negative.
I also wonder if there's something wrong with my solver instead, ie such results are definitely wrong...
Btw, I'm using a cambered airfoil. Previous test with naca0012 resulted in only postive efficiency.
Old   March 3, 2007, 12:05
Default Re: Negative propulsive efficiency of a moving air
H
are you using the relative velocty of your moving arifoil?
Old   March 4, 2007, 06:59
zonexo
what do you mean? The energy required to move the airfoil was given by P(in)=-lift force* dh/dt - Moment* d(theta)/dt
where dh/dt is the absolute up/down velocity of the airfoil.
P(out)= thrust*absolute free flow velocity, which is 1 in this case
thank you.
Old   March 6, 2007, 08:33
Mani
The way the propulsive efficiency is defined, there is nothing fundamentally wrong with a negative value. It simply means you create negative thrust (or drag). If you think this shouldn't be the case, check on the motion you are assigning (is it backwards?) and compare the flow solution with your previous solution on the symmetric airfoil. Anyway, it's very possible to create negative thrust, and hence, negative propulsive efficiency, as any hummingbird can tell you.
Old   March 7, 2007, 00:16
zonexo
Thanks everybody. I found that I've made some mistakes in the motion, which resulted in drag being produced most of the times. In the correct motion, thrust is generated ;-). However, as what Mani says, it's definitely possible, based on the definition.
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Airfoil simulation using moving wall Alejandro Fidelity CFD 9 November 4, 2008 02:00
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
Simulating an airfoil using a moving boundary Alejandro CFX 4 January 27, 2007 12:03
