March 8, 2007, 09:46 |
Which Model?
Hello,Im modeling a 2D NACA65A210 airfoil using GAMBIT and FLUENT....
My flow speed is subsonic, Mach 0.6 @0ft. I was wondering as experts on CFD your opinions on how i would go about selecting the best model. I have tried a number of variations, however i'm not sure what the 'official' model is for my conditions. Various sources tell me various models. i.e: 1) As my flow is subsonic, what should my vicous model be? 2) Should the energy equation be on or off? 3) Should my solver be coupled or segregated? 4) What discretization should i use (i.e pressure presto!?, momentum 2nd or 1st order? I hope you can help me out! Cheers, Julian. |
March 8, 2007, 10:31 |
Re: Which Model?
Turbulent, viscous, coupled, with energy equation (the physics demand it) turned on.
March 8, 2007, 10:48 |
Re: Which Model?
Thanks mate. Thats what my research was pointing to but i was unsure. I think im going to go with a k-epsilon viscous model.
As you can probably tell im new to CFD, and i'm learning it blind, with my only help being a CFD textbook, an aerodynamics textbook, and this forum- so help is much appreciated! |
March 9, 2007, 06:17 |
Re: Which Model?
Ok and at risk of looking like an idiot, for the discretization scheme, for flow, Turbulance Kinetic Energy, and Dissipation Rate, should i use 1st order upwind or 2nd order upwind?
Cheers in advance. J |
March 9, 2007, 10:55 |
Re: Which Model?
I would use the second-order upwind.
March 11, 2007, 01:28 |
Re: Which Model?
what is your application type. subsonic aircraft or supersonic aircraft
March 11, 2007, 17:59 |
Re: Which Model?
subsonic. Ive sorted a model now, thanks to you all (ag, and sa) for help!
question about turbulence model selection and sensitivity | karananand | Main CFD Forum | 1 | February 26, 2010 04:41 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 03:20 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
Reynolds Stress model in CFX vs Fluent | Tim | CFX | 1 | October 7, 2009 06:19 |
Grid resolution for full-scale and down scaled model | gravis | Main CFD Forum | 0 | October 2, 2009 10:27 |
