Handling boundaries in pressure equation using HYPRE
Old   March 12, 2014, 05:00
Default Handling boundaries in pressure equation using HYPRE
Hadi Zolfaghari
ata_benedict is on a distinguished road
When you pass your pressure domain to HYPRE solver, you need to give it the neighbor coefficients. This is implemented simply for the inner cells but for boundary cells(i.g. inlet and outlet in a pipe) it would be tricky. Because the solver eliminates the coefficients which are out of borders. Like upper neighbor cell coefficient in the outlet. How I can handle this problem?
ata_benedict is offline   Reply With Quote
hypre, poisson equation
Singular Linear System - Pressure Poisson Equation Allan Main CFD Forum 11 March 17, 2011 09:39
Pressure work term in turbulent K.E. equation lost.identity Main CFD Forum 0 March 8, 2011 12:21
The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver renyun0511 OpenFOAM Running, Solving & CFD 0 November 10, 2010 01:47
Dirichlet BC for Pressure Poisson Equation Chandra Main CFD Forum 11 October 29, 2008 03:32
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
