convergent channel
Old   March 12, 2014, 07:47
Default convergent channel
mojijoon is on a distinguished road
I am trying to model unsteady flow of gas at low speed in a convergent channel with finite volume method, using unstructured and co-allocated grid, with SIMPLE algorithm. But the answers from my code are diverging and I don't know what causes the problem.
I only consider the flow in 1 direction. Is this a wrong assumption?
velocity does not change respect to \theta so the grids become 2D, but when I want to calculate the area of faces I use area of 3d shape and for the normal vector I consider a 2D shape. Is it wrong? should I create a 3D grid regardless of velocity component?
mojijoon is offline   Reply With Quote
Open Channel Flow ElanMorin FLUENT 4 February 25, 2015 16:26
Question on the boundary condition for open channel flow, please help! ripperjack OpenFOAM Running, Solving & CFD 0 September 13, 2013 11:44
Need help : natural convection in inclined convergent channel Glare FLUENT 1 October 21, 2012 12:31
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 06:44
tecplot 3D velocity contours inside a channel vetnav Tecplot 4 July 14, 2010 20:03
