velocities and pressure
Old   March 16, 2007, 03:19
Default velocities and pressure
Palani Velladurai
Hi guys! I got confused with some basic flow quantities......
consider a channel flow , and my inlet velocity is some 30 m/s for a 2 m length channel.....and I set my outlet as a pressure outlet..In this case setting the values of pressure at te outlet from 0- 100000 Pascal..but I found no change i my velocities....That means ..there is nothing to be related between inlet velo and out.Pressure... or ????? reply me
Old   March 16, 2007, 08:10
Default Re: velocities and pressure
otd
What fluid? Density, viscosity = ?
Compressible or incompressible flow?
If incompressible, only the pressure difference counts. Check to see if p_in - p_out is the same for all of your results.
Old   March 16, 2007, 10:22
agg
For the pressure boundary condition you must be setting dp/dx=0 at the inlet. For the two solutions, check the pressure obtained at the inlet. They must be different. The pressure gradient however must be the same (difference between pressures at the inlet and outlet). This mean that the pressure at the inlet adjusts itself to maintain the same flow rate in both cases!
Two fundamental questions about icoFoam while updating the velocities and pressure dbxmcf OpenFOAM Running, Solving & CFD 6 April 12, 2016 16:05
Fluent natural ventilation pressure boundary condition pierresandre FLUENT 24 November 8, 2011 14:32
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
pressure boundaries allowing inlet velocities cirilo Siemens 1 September 7, 2005 03:21
Pressure Inlet yields wrong velocities Ben FLUENT 0 November 21, 2004 01:47
