Problems with accelerate flow. Underwater Vehicle
Old   March 18, 2014, 04:36
Default Problems with accelerate flow. Underwater Vehicle
Antonio Garrido
AntonioG is on a distinguished road
Hello to everybody, I'm new in this forum. I'm working in my master thesis trying to estimate the hydrodinamic coefficients of an AUV (Autonomous Underwater Vehicle). I have already calculated some of them at constant speed but I'm having problem when I try to accelerate the flow.
What I want to do is to impose a transient velocity conditión with constant acceleration so I can compare the results with the constant speed ones and obtain the so called added mass (virtual mass).
I've tried to set the intel velocity as a function of time, with velocity field function as Vx=constant*t.
The simulation converge but the problem is that the results make no sense, the velocity distribution and the viscous forces make sense but the pressure distribution doesn't and the pressure forces are too high.
I attach a picture of the pressure distribution so you can see can I mean.Presión, velocidad variable.jpg
Can somebody help me with this? I'm really stuck, and I tried a lot of combinations of inlet and outlets
Or Does somebody know another method to estimate the added mass?
Thank you very much in advance
AntonioG is offline   Reply With Quote
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
Significant Reversed Flow at Outflow Problems [ANSYS FLUENT] NormalVector ANSYS 1 May 15, 2012 23:50
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 06:44
problems for the flow over flat wall iilw1314 Main CFD Forum 0 March 19, 2010 04:53
problems in high speed external flow jon william FLUENT 2 January 14, 2007 06:37
