LSF Question - Off Topic
Old   April 9, 2007, 11:34
Default LSF Question - Off Topic
Andy R
Folks,
Figured that a lot of you use LSF and cannot seem to find an answer to this elswhere.
I would like LSF to touch a file (in my case stopgasp but it could be exit-fluent or abort for you star folks) which will stop the computation cleanly before the que time limit expires. According to the LSF manual (which I read) this can be done. However after a long Dogpile session (I use it not google) I have not been able to find an example where an actual unix command rather than an unix signal is issued.
The LSF option is -wa 'command'
LSF complains that my wa option is an invalid signal. I have tried back quotes, double quotes, double quotes in single quotes etc. No luck
Has anyone sucessfully used this LSF option with a unix command? How did you do it?
Any help is appreciated.
Andy R
PhD topic ...suggest me the topic harishr_jack Phoenics 8 February 3, 2013 05:35
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
PhD topic ...suggest me the topic harishr_jack Main CFD Forum 4 March 1, 2010 10:28
Question about Table applicaiton. universez OpenFOAM Running, Solving & CFD 0 January 12, 2010 20:31
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
