June 19, 2017, 09:00 |
Cfl
antony morgan
Rep Power: 8 |
hello friends. i'm trying to model a 3D dynamic airfoil. i'm using LES model. and SIMPLEC in pressure velocity coupling but i don't know what is the proper courant number in this case (LES & SIMPLEC). because of mesh study i need to know what is the proper CFL number.
setup: U_infinity=75.5 m/s viscous model =LES pressure velocity coupling =SIMPLEC chord lenght =0.2 m |
June 19, 2017, 09:55 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
I do not understand your question ... the CFL is a numerical parameter for the numerical stability constraint. It depends on the mesh sizes (3d), time step and velocity components. It is combined with the diffusive parameter. The general procedure is to fix the mesh sizes and determine the time step that allows for the numerical stability of the used scheme. It is important for explicit scheme. |
June 19, 2017, 16:17 |
antony morgan
Rep Power: 8 |
hello again. my question is that what is the desired CFL number in 3D modeling of dynamic airfoil when we use SIMPLEC for velocity pressure coupling and LES for viscous modeling
June 19, 2017, 16:26 |
#4 | |
Rep Power: 71 |
It is not a "desired" value but it is constrained by the numerical stability. It depends on the type of discretization. A classical constraint is cfl<=1, valid for some explicit schemes. |
CFL Adapt parameter | DLuo | SU2 | 3 | April 13, 2018 05:07 |
Utility of providing the CFL and the time-step simultaneously | Lise | STAR-CCM+ | 1 | January 31, 2017 08:22 |
CFL ramp option | curky | SU2 | 1 | April 11, 2013 13:25 |
CFL number in steady simulations | Rol | Main CFD Forum | 4 | August 20, 2010 09:17 |
implementing the CFL criterion | Ben Houston | Main CFD Forum | 1 | December 4, 2002 10:16 |
