heat transfer - heating element to air in FloWorks
Old   March 27, 2007, 14:56
Default heat transfer - heating element to air in FloWorks
Duncan Gravill
Hi All,
I Need help in understanding how to make a project in Cosmos FloWorks where there is a heating element surrounded by air and the heating element heats up over time and heat is transferred to the air around it. I want to analyse how the air around it heats up and any fluid motion in the air that is induced as a result of being heated. at the start of the the analysis the air around the heating element is static and any fluid motion should only be as a result of the air being heated.
thanks,
Duncan
Old   March 28, 2007, 20:16
Default Re: heat transfer - heating element to air in FloW
Duncan Gravill
I have found some tutorials that have been very useful,
if anyone else is interested here are the links,
http://personal.stevens.edu/~ffisher...Heat_tutor.pdf
http://personal.stevens.edu/~ffisher...valv_tutor.pdf
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Heat Transfer in a pipe flow(hot air) Saima Main CFD Forum 0 January 17, 2011 07:08
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 08:46
No results for solid domain Gary Holland CFX 10 March 13, 2009 03:30
flow and heat transfer of rarefied air Jon FLUENT 0 October 23, 2008 16:23
