April 25, 2007, 09:53 |
reg:Pressure dependencies with velocities
Hi ! I am doing 2d-flow past a cylinder (Unsteady-incompressible) Large Eddy simulations in fluent and try to capture the Pressure Fluctuations for 4 differnet velocities (dia,density, distance from the cylinder all are constant ) at a point located at the wake.
In regarding this , I would like to validate my meshes on the basis of Pressure fluctuations captured at my reciever location. In connection with that, I need some theoritical relations between Pressure and Velocity (and Dia and Distance also accounts) In M.M.Zdravkovich , I have found that Average of the Fluctauting (P')2 is proportional to the fourth power of velocity. How can I fix a value of theoritical Pressure on the basis of Velocity???? Will be the following relation will be a valid one ... since my density is constant (P ')2 = (RHO)2 * (V)4 If not, Please reply me , if anybody knows some thoeritical stuffs.... |
April 25, 2007, 11:15 |
Re: reg:Pressure dependencies with velocities
I don't see why you need a modeled relation between pressure fluctuation and velocity. Doesn't your CFD solution include both pressure and velocity? Why not get the pressure fluctuation (and/or velocity) directly from the unsteady flow field?
April 25, 2007, 17:58 |
You may use the energy equation that energy will always be constant.
potential energy + pressure energy + kinetics energy = constant z + P/pho.g + v^0.5/2.g = constant if the z =constant, then the pressure is inverse proportional to the velocity. |
Artificial high velocities at the interface using interFoam | Arnoldinho | OpenFOAM Running, Solving & CFD | 37 | August 30, 2018 06:25 |
how to get relative velocities in a rotating frame of reference? | alkochevsky | OpenFOAM Post-Processing | 14 | May 31, 2017 06:05 |
Interfoam Microchannel flow parasitic velocities | cfd_user2011 | OpenFOAM | 2 | June 12, 2011 15:43 |
Conversion of computed velocities in Lagrangian coordinates to Eulerian coordinates | SMM | STAR-CD | 4 | June 5, 2011 09:20 |
Derived velocities from loss coefficients ?? | jakjak | CFX | 1 | December 20, 2007 14:38 |
