May 19, 2007, 10:33 |
Ghost Fluid Method
If someone know this, please teach me how to set the ghost value across the interface.
Based on the isentropic assumption, for a single-phase compressible flow I obtained a sharp interface in the 1D shock-tube problem. On the other hand, I failed to get a sharp interface for a two-phase compressible flow. Instead, there was a spurious oscillation at the contact surface. Most error may be due to the complexity of numerical treatment in a mixed cell where both properties are involved. The reasons I can imagine are that in the construction of the slope-limiter with the eigen-vectors matrix, the computation in a mixed cell is not trivial. It is a vague. in the computation of flux(i.e. Lax-Friderich), the computation near the interface is very complex. Please give me a hint or some good sample code. Thanks in advance. |
June 6, 2007, 10:55 |
xdblzqog veaupig
tmdcoky eoqvh necuwtvg gvrifsm lkyrxfqn skdpomzil hosircu
June 6, 2007, 19:33 |
Re: xdblzqog veaupig
Hey! What does it mean? I couldn't read your language
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
for incompressible fluid projection method | mfclovegyy | Main CFD Forum | 2 | May 23, 2012 00:58 |
Volume of Fluid Method | Gitesh P | Main CFD Forum | 4 | January 29, 2010 09:48 |
ghost fluid method (GFM) | Amir | Main CFD Forum | 0 | March 3, 2009 03:38 |
Please help me 'ghost fluid method' | jinwon | Main CFD Forum | 2 | April 29, 2007 22:47 |
