May 29, 2007, 07:38 |
Residual?
I would like to have an idea about formulas for calculating the residual over a domain with uniform grid to fix the convergence criteria. Usually I use (Finite difference scheme): res = sqrt((Un+1-Un)^2/N) where N is the number of nodes. Is it correct??? |
June 1, 2007, 00:59 |
Re: Residual?
Usually, when you have an equation as d(u)/dt + L(u) = S
where L(u) is the spatial operator and S is the source, you tend to represent (L(u)-S) as the residual. For a steady state, this (averaged over all nodes) needs to be zero and hence the convergence criteria. There are many different methods. For finite volume, it should be the average and not the integral quantity for a stringent condition. (For smaller cells near the physical boundary, this tends to be higher) |
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 06:54 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
