slip wall boundary condition
Old   June 18, 2012, 01:48
Default slip wall boundary condition
Mehdi Baba Mehdi
mb.pejvak is on a distinguished road
Hi everyone
I read an article and there is mention slip wall boundary condition for far-field and is said it equals wall shear=0.
Can anyone explain what it means and what is differences between slip wall boundary and symmetry?
thanks so much
mb.pejvak is offline   Reply With Quote
Old   June 18, 2012, 05:55
sanjay's Avatar
aerosapien
sanjay is on a distinguished road
Hi mb.pejvak,
Slip condition refers to a surface where effect of shear stress is considers zero. In case of symmetric bodies we cut down the geometry to half to reduce computation size, memory and time. So the surface corresponding to cutting pane is called symmetry. Once done with the simulation of semi body a mirror option is used to create the another half.
cheers regards
www.aerosapien.blogspot.com
sanjay is offline   Reply With Quote
Old   June 18, 2012, 21:37
Mehdi Baba Mehdi
I know what you mean, but my problem is I can't find out what is differences between them in applying.
if we assume a dummy cell and named it 0 and cell near it in domain named 1:
in symmetric plane we apply U0=U1
and in slip wall also apply the same.
am I wrong?
Old   June 18, 2012, 23:22
Martin Hegedus
Martin Hegedus is on a distinguished road
In general, slip and symmetry are much the same, if not exactly the same. But, sometimes it is implementation dependent. For example one could have p(-1)=p(1) for symmetry but p(0)=p(1) for wall. Also, the turbulence model boundary conditions could be different. OK, I don't know what it means to have a slip turbulence model, but I guess that depends on what someone is trying to do. Also, a turbulence model could depend on the distance from a surface. So it's possible that setting a far field condition to a wall will affect the turbulence model.
But, the answer, to first order, is that they are the same.
Martin Hegedus is offline   Reply With Quote
Old   May 22, 2014, 04:49
itsme_kit is on a distinguished road
Hi
as far as I know, free slip condition is based on zero shear stress and stationary wall
How about in case of moving wall and zero shear stress? I guess the velocity of moving wall will determine the velocity of cell next to the wall
Is it right?
itsme_kit is offline   Reply With Quote
Old   May 24, 2014, 06:49
Shawn
pswpswpsw is on a distinguished road
Originally Posted by mb.pejvak View Post
Hi everyone
thanks so much
Hi Pejvak,
1. I don't know the relationship between your first sentence and the second.
2. The slip wall boundary I know, occurs when the local Kn number is high enough to cause slip velocity existence. The slip velocity is no zero but it does not mean wall shear is zero.
3. While for symmetry boundary condition, the shear stress is considered zero at the symmetry line.
Cheers,
Shawn
pswpswpsw is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
natural convection mehrdadeng CFX 10 February 25, 2011 05:25
Wall boundary condition in cylindrical co-ordinate shekharc Main CFD Forum 3 December 2, 2009 08:20
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
