June 3, 2014, 01:36 |
Need help for boundary condition
le hoang anh
Rep Power: 13 |
Hi everyone,
I am doing my numerical simulation of cavitating flow in rectangular Nozzle. I am having trouble with boundary condition. Firstly, I use mixed Neumman and Drichlet boundary condition at inlet and outlet section. Inlet is subsonic flow so that I fixed total pressure, flow direction and void fraction. Outlet also assume that subsonic flow, so just static pressure fixed. But the solution divergent due to very strong pressure wave propagation. I read in book that, for this situation, I need use non-reflective BC or Convective BC. example, convective BC at oulet: d(phi)/dt + U d(phi)/dx = 0 with phi: velocity, pressure, density, mass fraction,... But my question, if use CBC, how to fix the outlet pressure? And which boundary is suitable for my case? |
June 5, 2014, 13:45 |
N/A
Rep Power: 17 |
Check this paper
Poinsot T. et Lele S. (1992). Boundary conditions for direct simulations of compressible reacting flows. Journal of Computational Physics. 101, 1, 104-129. CBC will perform a decent job in absorbing the waves but may not be sufficient depending on the problem. An easy option is to have a sponger layer/PML to absorb the outgoing waves. Depending on your numerical scheme(if it is high-order), you can also use the energy transfer and annihilation method of Visbal. |
UDF for degassing boundary condition | peaker007 | Fluent UDF and Scheme Programming | 5 | November 23, 2015 12:55 |
pressure oulet condition | nam su | FLUENT | 2 | January 24, 2012 04:48 |
İnlet boundary condition | aggie | FLUENT | 10 | December 23, 2011 04:28 |
How to resolve boundary condition problem? | sam | FLUENT | 2 | July 20, 2003 02:19 |
The Boundary Condition about the Flat Plate | boing | Main CFD Forum | 1 | January 6, 2002 16:53 |
