LES questions
Old   June 25, 2007, 02:27
Default LES questions
Shuo
Do all LES use finite volume methods?
Old   June 25, 2007, 05:56
Default Re: LES questions
Dave
No
Old   June 25, 2007, 05:58
Shuo
WHat are the advantages of using finite volume over finite difference for LES?
Old   June 25, 2007, 13:17
phil
- Finite difference can use more accurate schemes (for spatial discretization). For LES this advantage is very important for academics research. If you can reduce significantly numerical error cause by discretization , you can most understand the effect of LES model.
-Finite volume can shape more sophisticated body. It's a very important advantage in the case of industrial research.
In the two case, you can use LES. But like everything, there are 'no magic solution'. In the two cases, you pay a price in order to have something.
Old   June 25, 2007, 20:48
Shuo
How long would it take to convert a RANS solver to a basic LES solver?
Old   June 26, 2007, 02:12
phil
I don't know.
Old   June 27, 2007, 09:02
Praveen. C
The difference is really between structured and unstructured grids. You can have very accurate finite volume schemes on structured grids but the same is not possible with unstructured grids.
Old   June 27, 2007, 10:15
jojo
You can, indeed, but at a very high cost. Furthermore, a high order shape function to reconstruct the fluxes and a high order surface integration impact the structure of the matrix and thus the robustness of the numerical method.
Old   June 27, 2007, 10:34
phil
You can't have the same accurate with finite volume. For example, you can't try a finite volume with the same accurate and cost than high order ompact schemes. And when you want to study some LES model or very special turbulence cases, finite volume is not the right way !
But you're right, -the- difference is really between structured and unstructured grids. But, really can you can explain that is the difference between finite volume and finite element in the case ?
LES basic and simple questions. dshawul Main CFD Forum 0 October 4, 2010 10:56
Some questions about LES in OpenFoam A.Devesa OpenFOAM Running, Solving & CFD 3 July 26, 2010 08:35
LES questions pp Main CFD Forum 1 March 14, 2005 05:04
LES.. Basic Questions NIK Main CFD Forum 8 May 19, 2004 18:24
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 09:58
