[Velocity-coupling] - why not least squares ?
Old   August 3, 2007, 15:35
Default [Velocity-coupling] - why not least squares ?
Lionel S.
Hi all,
It seems that velocity-coupling is a hudge problem. When using coupled solvers, the linearization can lead to a singular matrix.
SIMPLE is a good idea, but personally I had good results only at low reynolds numbers (less than 200). At high reynolds numbers, it seems that instabilities appears, especially with pressure boundary conditions.
Now I read several articles who told that anoter solution to avoid the problem of singular matrix is getting more equations than unknowns and then solving it with least squares method.
So why not ? Why is it not used more frequently by commercial solvers ? Did anyone try a least square method in CFD ?
Kindest regards
Lionel
Validation test for 2d euler equations in subsonic regime with canonical squares panou Main CFD Forum 2 August 24, 2011 15:21
Unregular Mesh with Squares. What to choose? starab Main CFD Forum 0 October 26, 2010 04:47
public domain f77 separable nonlinear least squares solver wanted Sergei Chernyshenko Main CFD Forum 10 January 28, 2000 13:56
