Ask: gamma-based method for compressible multiflui
Old   August 14, 2007, 16:27
Default Ask: gamma-based method for compressible multiflui
jinwon park
Is there anyone knowing the gamma-based method for compressible multifuild developed by Keh-Ming Shyue?
He suggested two advection equations to track the interface motion in terms of (1/gamma-1) and (gamma*PI/gamma-1).
Here the gamma is the ratio of specific heat, PI is a pressure-like constant used in the stiffend-gas EOS.
I am confusing how he solved these two equation either by coupled with the system of equestion or separated with them.
The system of equations is the conservative form while the advection equations is the primitive form.
Thanks in advance.
What is C.V. based finite element method C-H Kuo Main CFD Forum 4 September 19, 2022 14:06
incorrect temperature in pressure based solution Kian FLUENT 1 July 6, 2009 05:59
Code for most powerfull FDV Method D.S.Nasan Main CFD Forum 6 September 4, 2008 02:08
is there any method give node based velocity BC? daniel FLUENT 2 July 18, 2006 21:21
Boundary Conditions for LU-SGS Method Based on Overset Grids Aiming Yang Main CFD Forum 1 April 25, 2000 04:35
