Unit of Density Gradient
Old   August 16, 2007, 21:39
Default Unit of Density Gradient
Eric
Dear friends,
I got the Density Gradient in Tecplot360.
Could you tell me the Unit of Density Gradient?
Thank you in advance.
Eric
Old   August 17, 2007, 00:47
Default Re: Unit of Density Gradient
nobody
It should depend on the units of your density field and mesh coordinates.
Old   August 17, 2007, 01:39
Eric
Thank you.
I use the Unit kg/m^3 for the density, and Cartesian coordinate system.
Old   August 19, 2007, 21:23
Eric
Help me please.
Old   August 20, 2007, 09:33
ag
The gradient dimension is going to be (units of density)/(units of length). As nobody said - it depends on the units you are using. A cartesian grid system could have length units of meters, inches or parsecs. You should be able to figure this out.
Using Density Gradient C_R_G(c,t), Pressure Based Solver Anirudh_Deodhar Fluent UDF and Scheme Programming 1 October 25, 2013 05:43
salinity solar gradient pond (different density) prodriguez7 FLUENT 0 October 6, 2010 05:00
How to obtain density gradient? connyg FLUENT 0 December 18, 2006 11:32
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
Warning 097- AB Siemens 6 November 15, 2004 04:41
