How to define a circular I.C on carteisan mesh
Old   August 15, 2007, 17:12
Default How to define a circular I.C on carteisan mesh
jinwon park
I am solving the cylindrical wave propagation problem on the cartesian mesh.
Since the mesh is in the cartesian, the defining of cylindrical I.C. is was trivial.
I used the smoothed heaviside function as follows
FUNCTION heaviside(x,dx,dy,eps) IMPLICIT DOUBLE PRECISION(a-h,o-z) PARAMETER(PI=3.141598d0) IF(x .LT. -eps) THEN
heaviside=0.d0 ELSEIF(x .GE. eps) THEN
heaviside=1.d0 ELSE
heaviside=0.5d0*(1.d0+x/eps+1.d0/PI*sin(PI*x/eps)) ENDIF ENDFUNCTION heaviside
It worked well when the discontinuity is not serious(e.g. 1 to 0.1 or 2 to 0.2). However, when I solved a large gradient of a variable(e.g. 500 to 0.1 or 10e9 to 10e4), the initial condition became strange.
Even though the smoothed heaviside function gave a smoothed variation like 0.0,0.0001,0.85,1.000, a strange set of I.Cs were created.
That is, due to large gradient, a strange sharp hump was observed in the initial condition.
I wonder if anyone advice me how to define a circular I.C on a cartesian mesh.
Please help me... I need your help. Really.
Old   August 16, 2007, 11:06
Default Re: How to define a circular I.C on carteisan mesh
rt
(probably you like to have sharp interface)
you can define your cylinderical wave by zero level set of an scaler function (so you sholud define a distance field for initial configuration) and then use either diffusion-less HJ-solvers or use immersed boundary methods (i think S. H. Udaykumar work JCP 05 is suitable for you) for monitoring its propagation.
Old   August 18, 2007, 09:52
John Dongarra
?? Do u understand what u say? (poor english !)
The famous solution is the level set immersed boundary, i agree with the previous thread, the mentioned paper (there are seris of 3-papers, second one: http://dx.doi.org/10.1016/j.jcp.2005.03.032) is a good ref. complete details is presented (note that this Ref. is very famous and was in 25-top paper list of JCP).
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Flow past a circular cylinder mesh Turbulent Main CFD Forum 8 December 9, 2012 04:19
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
How to define a polyhedral mesh given the data to be removed from the previous one gabrielecfd OpenFOAM 0 December 15, 2009 12:36
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
