August 1, 2014, 08:31 |
NASACX conjugate heat transfer simulation
Dileep
I am trying to model a coupled turbine blade analysis with Fluent and Abaqus. Right now
only the external surface is coupled and the cooling tubes have film cooling with constant h and Tref. The abaqus code sends the surface temperature during an exchange and the Fluent code receives that and applies it to the surface by a user defined macro I have defined. The problem is I have defined the surface havin a thermal condition specified in terms of temperature. Thus Fluent updates the wall temperature with that received during the exchange after each iteration and never lets the wall heat up. What I need is the value to be initially applied as a initial condition and the wall to heat up with no specific condition as such. That is I want the wall material to heat up due to the received flux from the fluid. Any ideas of how to do this? Thank you for your help. |
conjugate heat transfer in porous media-variable HTC | hmasenger | CFX | 3 | June 21, 2014 07:57 |
Conjugate heat transfer problem | troyker | FLUENT | 1 | March 22, 2014 13:46 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Heat transfer in an unsteady-state simulation | Raed141 | FLUENT | 11 | August 7, 2009 17:17 |
Conjugate heat transfer problem with porous media | piko | Siemens | 1 | April 17, 2009 15:41 |
