Generate Fluid Volumes For Axial Turbine Blades
Old   October 22, 2019, 00:40
Smile Generate Fluid Volumes For Axial Turbine Blades
Thanushka
thanushka is on a distinguished road
I have created stator blades and rotor blades by using coordinates and used SolidWorks. However, I tried to create fluid volumes for those blades, to simulate in CFX and have not achieved yet. I need to generate the following kind of Fluid volume.
Could you please give me some insights on this?
thanushka is offline   Reply With Quote
Old   October 23, 2019, 04:35
fresty is on a distinguished road
You could use a Workbench setup of Bladegen->TurboGrid->CFX, which might be simpler and quicker. However, Bladegen may not facilitate curve parameterization, at least not conveniently.
fresty is offline   Reply With Quote
Old   October 23, 2019, 20:36
Thanushka
Thanks, Fresty. I have tried Bladegen. But it doesn't facilitate blade creating from given coordinates.
Old   October 24, 2019, 04:13
You could import coordinates directly from a .dat file, using data import wizard.
Old   May 16, 2020, 10:09
Smile Solution Found
Thanushka
The following video solved my problem.
https://youtu.be/0Qmm9sKQaFc
axial turbine, blade passage, fluid volume
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 17:36
Need to output surface pressure on blades in a vertical axis wind turbine kmallick OpenFOAM Post-Processing 1 October 21, 2018 23:08
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 19:42
Y-Grid and turbine blades Vitali CFX 7 June 22, 2009 06:46
