Mixing occuring faster than the experiment problem
Old   September 4, 2007, 07:24
Default Mixing occuring faster than the experiment problem
Lila
Hello, I'm doing a simulation investigating water mixing in tanks. The model involves two phases (fresh & saline water) and use of turbulent jets. I've used the RNG K-E model and VOS multi-phase model. It's an unsteady simulation and I've used a time step of 0.1 secs. Although FLUENT predicts velocity fields very accurately, mixing occurs much faster than the experiment. I've tried changing under relaxation factors with no success. Any ideas why this is happening? Any suggestions?
Please, help!!!
Old   September 5, 2007, 10:48
Default Re: Mixing occuring faster than the experiment pro
agg
Make sure your inflow conditions for K and E are similar to those in the experiments that you compare with. Also, if mixing occurs faster in your simulations, I do not understand how your velocities compare well with experiments.
Problem with Mixing plane Mitpostdoc FLUENT 0 July 26, 2011 14:31
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
problem with MFR model for multiphase mixing tanks Srinivas Main CFD Forum 1 November 7, 2005 14:16
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 09:11
