August 18, 2014, 10:08 |
difference between ideal gas and perfect gas
Shenren Xu
Rep Power: 15 |
(1) What't the difference, if any?
(2) To simulate low speed air flow at room temperature and 1 atm, which one suffices? |
August 18, 2014, 13:19 |
Rep Power: 18 |
Simplest answer - in an ideal gas the specific heats are constant. In a perfect gas the specific heats are functions of temperature. Both obey the same equation of state. For your case an ideal approximation is probably sufficient.
March 20, 2016, 08:09 |
Ideal vs perfect gas
NITW
All perfect gas are ideal gas but reverse is not true. Specific heat for ideal gas is only function of temperature but in perfect gas(inter atomic force is neglected),it has two types calorically perfect gas and thermally perfect gas......
Calorically perfect gas,here specific heat is constant.but in thermally perfect gas,here it is function of temperature only. Sometimes perfect and ideal gases are interchangeable. Hope it may helpful....... |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
How can model a real gas(not a perfect gas?) | immortality | OpenFOAM | 7 | June 25, 2013 06:53 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
