Getting the underlying data from a Journal Article?
Old   August 21, 2014, 17:53
Default Getting the underlying data from a Journal Article?
orangesky is on a distinguished road
Hi guys,
I'm running a heat transfer case and I would like to compare my Nusselt numbers against some other papers I have.
However, none of the papers I have give one of the key constants (i.e. heat flux) without which I'm just probing in the dark.
When a paper is submitted, the data needs to also be submitted so would anyone happen to know if there's a straightforward way to have access to that data? Or do I need to make a request to the journal?
Any help is much appreciated!
orangesky is offline   Reply With Quote
Old   August 21, 2014, 19:13
Lane Carasik
lcarasik is on a distinguished road
Originally Posted by orangesky View Post
Hi guys,
I believe you have to request the data directly from the author(s). The journal will probably not have access to that data.
lcarasik is offline   Reply With Quote
Old   August 22, 2014, 04:43
cfdnewbie
cfdnewbie is on a distinguished road
hm.normally, all publications should be written in a way that all the relevant information to reproduce the results is there. if that's not the case, the reviewers overlooked that.
If you are sure the information is not in there (maybe you can compute it from other values they have given?), the contact the authors directly, the journal will most likely not be able to help.
cfdnewbie is offline   Reply With Quote
Error when reading data file. WJXu FLUENT 7 September 1, 2015 19:34
Extract data we want from Techplot to a data file vetnav Main CFD Forum 0 July 28, 2010 20:17
[OpenFOAM] Cell Data to Point Data Issues mcintoshjamie ParaView 2 November 19, 2009 03:55
help needed about phase change Yanhu Guo Main CFD Forum 4 January 23, 2001 23:16
Gambit Journal File Scripts, Public Database Needed? Jonas Larsson Main CFD Forum 13 March 2, 1999 07:25
