s-omega model for hypersonic folw for Mach>10
Old   September 27, 2007, 10:45
Default s-omega model for hypersonic folw for Mach>10
margarita
I have the problem with turbulence modeling up for hypersonic flow with high Mach value( >10). I try to use Baldwin-Lomax and k-omega model, but it doesn't work. I try also k-eps and S-A, the same problem. I would like to use s-omega model, proposed by David C. Wilcox in his book "Turbulence modeling for CFD (2006)". Thank you in advance for your help.
Margarita.
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 02:08
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 09:02
Turbulence Model and limitation to Reynolds number qascapri FLUENT 0 January 24, 2011 10:48
Use of k omega turbulence model john_w OpenFOAM Running, Solving & CFD 2 September 22, 2009 05:15
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 20:51
