Induced Circulation Ratio - Formula
Old   October 10, 2007, 13:34
Default Induced Circulation Ratio - Formula
Nick Reale
I am looking for a formula to measure the amount of fluid movement when fluid is pumped into a large body of water via a 2.175 diameter discharge at 10 PSI moving 10 GPM horizontal to the surface in 5 feet of water.
The project is to find which is more efficent circulation, vertical "bubble aerators" or horizontal discharge in reagard to water movement and mixing.
Most aerator manufacturers use what they call the Induced Circulation Ratio which they estimate is 2 to 5 times the actual pump volume.
That is not "close" enough for this project. Any help would be appreciated.
[ICEM] Error in Prism Ratio Computed singer1812 ANSYS Meshing & Geometry 0 September 22, 2011 16:29
pressure eq. "converges" after few time steps maddalena OpenFOAM Running, Solving & CFD 69 July 21, 2011 07:42
How to calculate circulation ? taalf Main CFD Forum 4 May 6, 2011 10:13
diesel spray combustion equivalence ratio usker Siemens 12 March 1, 2008 06:09
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
