Reading experimental data for case validation |
September 24, 2014, 03:39 |
Iman
Rep Power: 12 |
can any one help understand the results that is listed in the attached file? i got it from this case listed in the database
http://cfd.mace.manchester.ac.uk/cgi...&1&1&1&unknown i'm trying to compare between this experimental results and my simulation which i has done in FLUENT. but i really can't figure out what are these readings and why there is several columns/raws if the measurements are done at a certain location?! thank you in advance |
September 30, 2014, 02:30 |
Iman
Rep Power: 12 |
although no one responded to me. but i already figured out what is the content
[Commercial meshers] fluentMeshToFoam: "fluent patch type shadow not recognised" | preibie | OpenFOAM Meshing & Mesh Conversion | 28 | March 29, 2017 04:56 |
Data Produced From Fine Marine Cant Match with The Experimental Data | PeiSan | Fidelity CFD | 4 | August 23, 2014 05:33 |
Experimental data validation and/or grid independence | svp | Main CFD Forum | 5 | June 6, 2014 03:24 |
experimental data for code validation | Ambrose | Main CFD Forum | 4 | May 4, 2004 14:33 |
Experimental data for fence at low Reynolds number | Kim Bindesboll Andersen | Main CFD Forum | 1 | September 26, 2002 13:54 |
