reference needs, pressure inside droplet
Old   October 12, 2007, 06:20
Default reference needs, pressure inside droplet
Junseok Kim
I am looking for a numerical simulation reference for finding pressure field inside falling droplet under gravity.
thank you in advance
Old   October 14, 2007, 09:11
Default Re: reference needs, pressure inside droplet
momentum_waves
What pressure distribution would be obtained by holding the droplet stationary & having the airstream rush past it.
A hint - consider a 3d simulation with the flow situation rotated clockwise through 90' & air flow approaching from the left.
The droplet will have an outer surface, enclosing a compressible fluid. The rest is up to your imagination.
mw...
<www.adthermtech.com>
Installing OpenFOAM-1.5-dev on a cluster ZKM OpenFOAM Installation 4 December 25, 2010 15:59
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile val46 OpenFOAM Installation 4 August 27, 2010 03:43
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
