Help on STAR-CD modelling helium injection in closed room.
Old   October 21, 1999, 04:14
Default Help on STAR-CD modelling helium injection in closed room.
Pavan Sharma
I am trying to model a scenario of helium injection in a closed room. I am a new user to STAR-CD. I have tried helium as a Scaler. I have used inflow boundary condition with finite Z velocity component. The code warns about the imbalance in mass conservation in absence of outflow boundary condition. Can somebody, a reguler user of STAR-CD help me teaching multicomponent gas distribution studies in a closed room. Alternatively, is any other freely availbale tool exist in this regard.
Pavan Sharma 411,HALL-7 RSD, BARC Trombay, Mumbai India
pksharma@magnum.barc.ernet.in
Old   October 21, 1999, 12:02
Default Re: Help on STAR-CD modelling helium injection in closed room.
Robert Bland
Your approach will not work steady state as you will eventually pressurise the room to an infinite pressure as you are continually adding mass. That is why the code is warning you about a mass imbalance. You will have to run this as a transient with physically realistic values for the injection rates and timescales. I am assuming that you are trying to match an experiment so this would give you suitable values. Otherwise you will have to devise credible values yourself.
An alternative to the inlet boundary would be a scalar mass source but this will obviously not solve the basic physical problem of trying to run this type of problem steady state.
Old   October 22, 1999, 06:13
Pavan Sharma
Thanks Mr. Robert Bland
I have formulated it as a transient problem it self. I could solve the problem using proper equation of state which is required for the compessible formulation. Please give your email add. also.
Pavan
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
Modelling airflow distribution in a room gangstagan FLUENT 1 January 21, 2011 12:51
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
airflow modelling in a room shahriel FLUENT 3 September 4, 2008 10:34
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
