stream function theory
Old   November 8, 2007, 12:12
Default stream function theory
Student
I don't know if I'm right here, well I will try... I'm looking for a code (open & free) to calculate the stream function in cylindrical coordinates. Can anyone help? Thanks in advane
Old   November 8, 2007, 18:46
Default Re: stream function theory
Ahmed
You have reached this forum, click on the button "Links" (Top menu bar" then select "software" from the drop down menu
Old   November 12, 2007, 02:43
Student
Thank's... I've already tried this, but what I'm looking for is only a very simple code or programming example for educational purpose, to show the implementation of stream function theory. Ideally I would like to model as an example the stream function in cylindrical co-ordinates, e.g. the meridional flow through a pump (incompressible).
Old   November 12, 2007, 11:28
Ahmed
You need to check the classical CFD works by Clive Fletcher, Chung (FEM in CFD) or Klaus Hoffman (FDM)
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
