November 14, 2014, 13:45 |
Gas turbine network with Chemkin
Gökhan Varol
Rep Power: 11 |
Hello everybody. I'm new in here and could not find a general topic about Chemkin. Hope you can help me about an issue with PSR reactor in Chemkin.
I have modelled a reactor with 10 pcs PSR and two pcs. PFR reactors. My question is about cluster properties of PSR reactors. There is an input tab for initial temperature. What ı should enter in here? Temperatures are already identified in inlets for fuel and air. Also, when I enter and change any value in this tab, results are changing. If ıi leave empty, software giving error. As I know , PSR should calculate temperatures of reactor. You can find properties screen in picture. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Gas turbine in CFX | rahat69 | CFX | 4 | April 11, 2014 23:44 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
