unsteady flow, when do you use steady when do you switch to transient
Like Tree21Likes
  • 5 Post By jpc
  • 3 Post By vicarious
  • 2 Post By jpc
  • 2 Post By vicarious
  • 5 Post By FMDenaro
  • 1 Post By jpc
  • 2 Post By FMDenaro
  • 1 Post By Far
Old   November 2, 2012, 11:46
Default unsteady flow, when do you use steady when do you switch to transient
jpc
JPConway
jpc is on a distinguished road
this "philisophical" debate seems to be coming up more and more often.
flow is almost always turbulent and in essence, all problems are transient.
but generally for most problems you're interested in trends and are ok with a steady state solution.
when do you make the cross-over to transient?
some ideas:
1. at a certain reynolds number?
2. when you know a specific phenomena may occur? (vortex shedding for example...are there others? how do you know )
3. for any particular case of interest from the trend studies?
4. for final analyses? (for all or just the ones of interest?)
side question, when working with someone that isn't tuned into the world of CFD or fluid dynamics. how do you best explain turbulent flow vs unsteady flow? I found a really good example using a river, but am interested in any others people might have.
jpc is offline   Reply With Quote
Old   November 2, 2012, 13:14
vicarious's Avatar
Pedram Mojtabavi
vicarious is on a distinguished road
Send a message via Yahoo to vicarious
Hello jpc,
As you mentioned, some flow behaviors should be considered unsteady all the time, for example vortex shedding, combustion, chemical reaction, multi-phase flow, turbulent studies etc. In my opinion, When sth specific is changing in your domain you need to consider unsteady simulation, But sometimes you want to determine a performance of a system, for example drag/drift coefficients of an airfoil, then you can run a steady simulation. Although some cases could be treated unsteady at the first place and then become steady. briefly it depends to what goal you are after in a numerical simulation.
Regarding to your last question, turbulent flow is always a unsteady phenomena. In some turbulent cases, you cannot run a steady simulation because of high turbulent intensity and the solver cannot resolve the high gradients of parameters even with relaxations. Other cases of turbulent flows result in a steady pattern of flow when you need to determine a specific performance, pressure drop in a straight pipe at igh Re, but inside is a high turbulent flow, high pressure gradients and etc.
Hope it could help.
6863523, Oula and farzadmech like this.
vicarious is offline   Reply With Quote
Old   November 2, 2012, 13:22
jpc
JPConway
hi vicarious, thank you for your input.
regarding the situations that need to be run as unsteady (transient), how do you determine which need to be run that way?
do you just have to be an expert in the phenomena?
are there specific parameters to look at..etc.
6863523 and Oula like this.
Old   November 2, 2012, 13:58
vicarious's Avatar
Pedram Mojtabavi
As I said, It mostly depends on to what exact purpose you are interested in. Of course expertise is important. Parameters do not determine the unsteadiness of flow. In a low Re fluid flow, just because the flow is laminar, does not mean it is steady. You need to realize that the phenomena you are tracking has what kind of effect in your flow field. Another simple example, Filling a tank with a fluid cannot be simulated steady because the pressure is always changing, or all the problems involve a secondary flow, turbomachinery studies & etc.
Old   November 2, 2012, 16:38
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Steady simulations can be performed also for turbulent flow that are in energetic equilibrium. This is however a statistical meaning of the steady state, and is usually associated with RANS formulation.
URANS is a transient simulation in statistical sense.
LES and DNS are transient simulations with different meaning in the resolved fields.
A deterministic steady state is valid only for laminar flow (low Re number)
Far, Reggio, 6863523 and 2 others like this.
FMDenaro is offline   Reply With Quote
Old   November 3, 2012, 01:27
cfd seeker is on a distinguished road
Some flows are inherently transient e.g Wing/Aerofoil at High angle of attacks, shock-shock interaction, shock-boundary layer interaction. I always explain the steady and transient phenomenon to some like this....The flow around a wing or aerofoil at low angle of attacks(0,1,2,3 degree) can be considered and solved with steady solver because there is always negligible amount of flow separation(of course flow separation is highly unsteady) at these angle of attacks however with increase in angle of attacks the flow separation becomes prominent especially near stall so you will switch over to transient solver to properly capture the physics of the problem. So in short you should master physics of the problem in order to correctly approach it.
Regards
cfd seeker is offline   Reply With Quote
Old   November 9, 2012, 16:45
jpc
JPConway
thank you everyone for your input
from a practical standpoint, how do you imploy steady state solutions in your every day CFD usage?
for example you want to evaluate 20 different airfoils, at 20angles of attack at a high enough velocity that would be considered beyond transition (turbulent flow guaranteed), it really isn't practical to run 400 CFD solutions as transient. would you approach the problem from a steady state first and then move to transient for the cases that are of the most interest?
Oula likes this.
Old   November 10, 2012, 04:20
From a pratical (and rigorous) point of view, you can run only the RANS formulation in a steady state solution as you look for a statistic solution. No other formulations (URANS/LES/DNS) can be run by fixing to zero the time-derivative of the variables.
Old   November 10, 2012, 11:07
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
What is the physical significance of running the URANS?
In laminar case, for example cylinder at Re= 200 is laminar flow, but you consider it unsteady due to vertex shedding. And solving through URANS will give the trend of vortex shedding behind cylinder. Now few questions arises:
1. URANS in laminar flow regime (statistical as suggested) will be equal to LES as there is only single mode of unsteadiness? Am I right?
2. How do we compare the URANS and LES results? Which parameters we must consider e.g. mean.
3. Why transition models are successful for turbomachinery? They are able to predict the all modes of transition including natural transition.
4. Why there is very less difference in RANS, URANS and LES for mean quantities for the practical flows?
Far is offline   Reply With Quote
Old   November 10, 2012, 17:48
1. No, my idea is that URANS have a model which acts also on resolved part of the unsteadiness. Hence, on laminar flows LES is able to reduce to a DNS, URANS no.
2. Yes, zero order statistics should be comparable. High order statistics can be computed only in LES.
3. I have no experience in turbomachinery
4. No, I don't think that the differences in the mean between RANS/URANS and LES solution is always disregardable.... It depends on many factors..
Old   November 10, 2012, 17:55
Far
Sijal
I wanted to ask that prviously transition prediction was only possible with LES, now RANS models can also predict the transition from laminar to turbulent with good success.
At design condition. For example wing at 4 deg AOA. Obviously at the stall flow there would great difference among them.
Old   November 11, 2012, 18:40
iman
iman is on a distinguished road
thank you guys for your valuable discussion. i got alot of hints.
i want to simulate sewer pipelines for a certain study and analysis of sewage flow properties and i'm standing in between transiet, steady, turbulent characteristics. and it is really difficult to make the right decision and be confident about it!!
i want to start from simple and change the complexity of my design step by step to ease the study!! but i'm a little worried about the effect of over simplification!!
iman is offline   Reply With Quote
Old   November 12, 2012, 11:33
Do you mean that transition models are best only for turbomachinery applications? Do you have any supporting material for this claim?
Again I want toa sk do you have any supporting material for this because I think there should be an appreciable difference between the URANS and LES results
Old   November 12, 2012, 14:58
vicarious's Avatar
Pedram Mojtabavi
Guys,
What do you think about the difference between turbulence phenomenon and turbulence modeling?
I believe that the turbulence phenomenon lies in our classic laws naturally. These laws are a series of nonlinear partial differential equations. This turbulence is not completely known to humanity and the only strong solution for these equations is numerical methods. This is the difference between turbulence phenomenon and turbulence modeling. Numerical correlations consists of simple math procedure based on the computational domain we create. When the regime is turbulent, these simple math procedure (summing, multiplying, etc.) fail to handle the high extreme fluctuations in parameters. Thus, turbulence modeling is created because we need them in numerical simulation.
I suppose that when intensity is high, such flows in turbomachinery including large separations, large passage vortexes, high amplitude oscillations; only unsteady solvers will give the correct answer. DNS and LES methods are definitely more accurate specially in turbomachinery.
Old   November 16, 2012, 00:59
jpc
JPConway
for those that responded, how many of you use RANS tools and how many use LES/DNS tools?
those that use RANS tools, how often do you move from steady state to transient?
for transient solutions, how do you determine the length of time to run the solution? (in cases that aren't transient specific...ie where something is turned on and you want to see it develop over time)
for those that are responding, what types of problems are you solving? (transient and/or steady)
overall it seems like the answer to my original question is that the key is understanding the physics of the problem before accepting a steady state solution. most cases are transient in nature and should be run as transient and that one must be careful about using a steady state solution.
i'm not 100% sure that i am a proponent of that because of the wide variety of applications i'm exposed to, but i have a feeling that those that responded likely perform simulations in the same application group type and/or based on the tools that you use. see questions above.
Old   November 16, 2012, 04:09
I am not sure to understand the real sense of this topic...
In nature, steady laminar flows are quite rare ... in the most part of cases, the natural state of the flow motion is unsteady and turbulent
Old   November 16, 2012, 12:05
jpc
JPConway
FM, that is exactly the point. Hence, how do you explain a steady state solution in that case and how do you apply them. The extension of the question is more about the application of transient because in general, having used and supported solidworks flow simulation for over 8 years, I have seen only a handful of people use transient.
Old   November 16, 2012, 13:10
in laminar flows is a physical condition in deterministic sense, unlike in turbulence where is a statistically steady state. In the latter case, you need of an energy equilibrium as well, otherwise you have no steady state.
Old   November 16, 2012, 13:25
Far
Sijal
Just take an example of Turbomachinery. We all know that the flow in the turbo-machinery is highly 3d, transient, turbulent and complex, but still we do the steady state simulations. Why? And question arises when to use the steady state and when to use unsteady?
In my point of view it depends on the requirment. For example if we are interested in the mean values, like pressure ratio, mass flow rate and efficiency then we use steady state. But if we are interested that what be the effect of interaction of components on the pressure ratio, mass flow rate and efficiency during different relative position of upstream and downstream components then we use the transient simulation. Moreover in the case of stall, where flow is not taking a single value of these variables then we are forced to use the transient simulation, as we dont have any single answer and it keeps on changing with each iteration and we wont get the acceptable convergence.
Oula likes this.
Old   November 17, 2014, 11:17
Default hi
  #20
Qureshi M Z I
m zahid is on a distinguished road
hi, can anyone list the steps to perform unsteady analysis by standard k-epsilon model. (fluent 14.0)
thanks
m zahid is offline   Reply With Quote
transient, impregnating flow problem fgommer FLUENT 0 February 29, 2012 16:10
Poor Convergence for Transient Subsonic Diffuser sims with flow separation TWaung CFX 1 April 16, 2009 08:25
using steady state results for unsteady flow siva appanna Main CFD Forum 3 February 20, 2006 05:29
Unsteady AND Steady mode for Fully Developped Flow Dominique FLUENT 5 April 16, 2004 17:58
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 14:37
