December 3, 2007, 06:00 |
LES
I would like to study decay of vortices structures behind a vortex generator at Re_bulk=5000 in a plain channel, isn't LES a bit of an overkill there ?
December 3, 2007, 17:27 |
Re: LES
hi, i also work on LES. But what exactly, your problem is? Can you tell?
December 4, 2007, 07:51 |
Re: LES
I would like to quantify the viscous dissipation of the structures behind the winglet and link it with the heat transfer. I would like to compare stationnary RANS and non stationnary calculations.
December 4, 2007, 17:00 |
Re: LES
which type of winglet u are using...delta wing or winglet pair....Which paper you would like to compare , related to RANS?
December 7, 2007, 03:37 |
Re: LES
I want mainly to compare with "Heat transfer in a rectangular channel with a vee-shaped vortex generator" by Sohankar. However, I have a single delta winglet while he have two. He uses dns and LES, and found the results comparables.
December 6, 2007, 23:37 |
Re: LES
If I understant correctly, your Re_bulk is not very high. Can you not attempt a DNS? If DNS resolution requirements are too high, I think attempting LES is quite reasonable. If you could explain why you think LES for this is an overkill, I might be able to explain better.
December 7, 2007, 03:38 |
Re: LES
I thought LES was interesting for high Reynolds numbers (more than 10000), but for less, RANS and URANS might be sufficient.
December 7, 2007, 17:08 |
Re: LES
Yes that is correct. So, with the present computational power, computing DNS for your case should not be much effort, don't you think?
December 25, 2007, 16:18 |
Re: LES
hi, For the winglet problem....Do, anyone need to satisfy Y+=1 around the winglet body also? as near the wall it must be a criterion for les? Can anyone tell what is the reason?
LES basic and simple questions. | dshawul | Main CFD Forum | 0 | October 4, 2010 10:56 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 11:35 |
LES grid mesh | L3munoz | Main CFD Forum | 0 | April 7, 2010 05:05 |
LES on two phase flow | Li Yang | Main CFD Forum | 0 | May 12, 2004 08:10 |
Some Questions about LES. | Bin Li | Main CFD Forum | 2 | February 20, 2004 09:58 |
