Home > Forums > Software User Forums > COMSOL
Free surface Inlet-Outlet BC for a two-phase model - COMSOL MP (4.4)
Old   November 22, 2014, 10:01
Default Free surface Inlet-Outlet BC for a two-phase model - COMSOL MP (4.4)
Amin Rahmat
aminrahmat is on a distinguished road
Dear all,
I am trying to simulate a laminar two phase flow passing over a cylinder with a phase-field model where the cylinder is submerged into the water (heavier fluid), as a part of my project. I have tried a couple of candidates for the boundary condition at the inlet and the outlet. Initially, I gave a uniform velocity at the inlet for both phases plus a zero pressure at the outlet, then I assigned a mass flow rate for both phases and mass flow rate at the exit and a few other failed attempts. Also I have tried to give a step function at the inlet for the volume fraction at the level of my free surface and give a uniform velocity which I could not even implement.
Receiving a piece of advice, I have recently tried to give a zero pressure gradient at both sides and a body force or a small acceleration in the x-direction (as my driving force), but it seems that after sometime (4% of run-time in my case) the "reciprocal of the step size" increases and causes a failure.
I would be glad if there is a solution for the problem.
Amin,
aminrahmat is offline   Reply With Quote
boundaries condition, comsol 4, free surface flow, two-phase flow
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
Free surface is not falling (VOF MODEL, TANK DRAINAGE) Blue FLUENT 3 November 28, 2013 05:51
free surface outlet novice Siemens 2 October 19, 2005 07:31
About free surface model? Cheng, Y.C. Siemens 0 September 9, 2002 09:11
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
