How to approach calculating a stream function given a velocity profile on a grid
Old   October 24, 2009, 15:44
Default How to approach calculating a stream function given a velocity profile on a grid
Eric Jase
ComFlu is on a distinguished road
I have the velocity profiles for a 12x12 grid. So a 12x12 grid for the velocity in the x direction (u) and a 12x12 gride for velocity in the y direction(y) the stream function is defined as u=d(phi)/dy and v=d(phi)/dx. Where phi is the stream function.
This is a cavity flow: At the left, right, and bottom of the grid, the walls are stationary, therefore phi=0. To the right the change in phi (d(phi)) is the velocity in the y direction (v) times the change in distance going to the right (dx).
Denoting each grid line in the x direction as i, In summary:
d(phi) = dy * u ----> (phi)i+1 = (u)i*(dy)i+(phi)i
Thoughts on my approach?
ComFlu is offline   Reply With Quote
Old   October 25, 2009, 13:25
otd
private
otd is on a distinguished road
[QUOTE=ComFlu;233904]I have the velocity profiles for a 12x12 grid. So a 12x12 grid for the velocity in the x direction (u) and a 12x12 gride for velocity in the y direction(y) the stream function is defined as u=d(phi)/dy and v=d(phi)/dx. Where phi is the stream function.
If u = d(phi)/dy then v = - d(phi)/dx. The minus sign is mandatory. [Or you can go with u = - d(phi)/dy and v = d(phi)/dx. If you carry the signs consistently throughout the derivations, either will work.]
otd is offline   Reply With Quote
[UDF] Relative coordinates in logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 25 July 13, 2017 03:44
Logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 0 April 23, 2009 19:09
[boundary condition] logarithmic velocity profile cfdworker FLUENT 2 April 17, 2009 23:36
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
particle velocity and velocity profile HGG FLUENT 2 June 10, 2001 16:32
