How to set LES simulation, what one should know? |
December 8, 2014, 11:38 |
Danijela Djuric Mijovic
Rep Power: 12 |
Hallo everybody,
Until now I dealed with RANS only considering wind flow in an empty domain and getting the pressure coeff on the facade walls. I manage it after a lot of learning. Now I need to find out maximum and minimum pressures on the same walls. Is it too complicated? What I should know? Where I can find it? When I tried I was confused with the following: total time, time step and initial time? I don't have a hint what values should be there. Thank You people! |
December 8, 2014, 11:52 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
The problem solved with LES is not only depending on the good mesh resolution and proper time step, but you need to face a real time-dependent case which is really different from RANS. Thus, you need to wait until the numerical transient is finished, then sampling the fields to perform statistical analysis |
December 8, 2014, 11:59 |
Rep Power: 12 |
Thnx for quick reply. Any paper, literature?
December 8, 2014, 12:11 |
Rep Power: 71 |
December 9, 2014, 16:04 |
Rep Power: 12 |
Thank You! i will try... not much time
correction of Grub after installing Windows XP and 8 | immortality | Lounge | 20 | January 5, 2014 17:41 |
How to conduct transient LES simulation | tianrenshui311 | FLUENT | 0 | November 15, 2010 13:21 |
how to set electric permittivity in plasma actuator induce flow simulation. | mukut | Phoenics | 3 | November 1, 2010 21:50 |
How to show the transient case? | H.P.LIU | Phoenics | 7 | July 13, 2010 04:31 |
LES simulation of vibrating Wing | gtg627e | OpenFOAM Running, Solving & CFD | 0 | September 6, 2007 01:36 |
