analysis of wind turbine blades
Old   July 12, 2005, 13:19
Default analysis of wind turbine blades
sharuk
i've a doubt regarding analysis of wind turbine blades in fluent, do we need to model the blade with the twist or it should be straight to get same AOA over the whole span,which one is correct, i'm using periodic boundaries on either side ,inlet, outlet and a wall on top, do we need to give rotating reference. thanx in advance sharukdear@gmail.com
Old   July 16, 2005, 13:14
Default Re: analysis of wind turbine blades
Mani
Just think about it: Assuming uniform wind velocity, the incoming axial velocity component is independent of the radius. However, the circumferential component of the relative velocity varies linearly in span direction, because of rotation.
There is no way to get the same AOA over the whole span on a straight blade.
What do you mean by 'top' ??
Old   July 16, 2005, 14:40
sharuk
i'm using wall condition insted of farfield, is it correct, i was not getting through the periodic boundary condition so i've meshed for full model, how can i get the rotational velocity of the rotor in fluent, the blade section at tip will be a bluff body initially, so, how much rps i've to give, is it relative or absolute rotating frame, thank u
Old   April 24, 2009, 05:23
Default Windrotor simulation in cfd
sivaramakrishnaiah
sivarama1 is on a distinguished road
Send a message via MSN to sivarama1 Send a message via Yahoo to sivarama1 Send a message via Skype™ to sivarama1
Hi, everyone:
Can I use the Turbogrid to mesh the flow field of a wind turbine blade?
I know the Turbogrid and ICEM can mesh an internal flow turbomachine easily such as gas turbine and water turbine. But I'm not sure whether it can mesh an external flow rotor like wind turbine. Does anyone has some experience and give me some advice?
Thank you!
sivaramakrihnaiah
sivarama1 is offline   Reply With Quote
Old   June 22, 2009, 06:45
Default 3Dwind turbine rotor_cfx-11_error
sivaramakrishnaiah
Hi all,
FATAL ERROR : |
| Initial values are required for all variables in TRANSIENT runs. |
| In this simulation, no initial value was set for |
| Variable : Pressure |
| Domain : rotordisc |
| The value can be set using the Initial Values panel in CFX Pre. |
| To bypass this message and use default solver initial values, |
| set the expert parameter "transient initialisation override = t"
sivaramakrihnaiah
Old   April 20, 2010, 05:20
Default power out put
yashwant
saini.yashwant is on a distinguished road
Originally Posted by sivarama1 View Post
Hi, everyone:
Thank you!
sir can u help me to get the wind turbine analysis with fluent for boundary condition and calculating power
saini.yashwant is offline   Reply With Quote
Old   April 20, 2010, 05:25
Default wind turbine blade
sivaramakrishnaiah
Hi
In Turbogrid software willl use onlt internal flow problam,
actually wind turbine blade External flow problem. Here there is no domain,
My skype Id:sivaramakrishnaiah1
MY google talk ID:malayathisiva@gmail.com
sivaramakrihnaiah
Old   December 9, 2014, 18:59
Default who can i calculate the power of wind turbine blade at different AOA
zahid
zahid hussain is on a distinguished road
how can i calculate the power of wind turbine blade at different AOA
plz hlp me
zahid hussain is offline   Reply With Quote
Wind Turbine Analysis Suggestion andrea.pasquali OpenFOAM 13 March 25, 2015 05:27
FSI - Wind Turbine AUN CFX 13 August 29, 2012 16:44
CFX Analysis of a wind turbine Bournegenius CFX 16 August 20, 2012 19:16
Analyses and Design of Wind Turbine Blades, please help!!! heavymag Main CFD Forum 7 April 13, 2012 16:51
Usage of Star-CD in analysis of Wind Turbine Manabendra M. De Siemens 5 January 6, 2007 23:42
