December 14, 2014, 17:23 |
Camber Line Formula Query
Rob
Rep Power: 11 |
I'm trying to recreate an airfoil as a camber line and apply thin airfoil theory to it, however I'm having some issues with the NACA 4 digit camber line formulas.
Most sources say the camber line formula is: Front Yc=M/P^2 *(2Px - x^2) when 0<x<P Back Yc=M/(1-P)^2 *(1-2P+2Px-x^2) when P<x<c However when I try to plot this in Excel using any 4 digit NACA airfoil it most definitely does not produce a camber line, more like two disjointed downward slopes. In my searching I also found this formula on Wikepedia, which I wouldn't normally trust but this actually gives a camber line as expected!?! Front Yc=M *x/P^2 *(2P-x/c) when 0<x<P Back Yc=M *c-x/(1-P)^2 *(1+x/c -2P) when P<x<c Now after some rearrangement the Front formulas turn out to be identical apart from the 'c' term and the Back formulas I can't quite work out. Anyway so I'm trying to follow the thin airfoil theory calculations to eventually find CL and moments etc but I can't follow the rest of the calcs as using the Wikepedia formulas doesn't give the same answers once differentiated. I can't understand why Wikepedia appears to be correct and every other reliable source isn't!!?!? Can anyone shed some light on this for me please? |
[OpenFOAM] an error in Calculator's equation | immortality | ParaView | 12 | June 29, 2021 00:10 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
[Gmsh] Conversion Error | nuovodna | OpenFOAM Meshing & Mesh Conversion | 14 | October 1, 2010 11:07 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
