January 7, 2008, 01:15 |
TVD scheme
In the upwind TVD scheme(Yee 87) there's an expression that reads
gamma = 0.5*Psi(a_(i+1/2, j))*(g_(i+1, j) - g_(i, j))/alpha_(i+1/2, j) a is the eigenvalues of the Jacobian matrix A g , alpha and gamma(?) are both column vectors i.e. g = transpose(g00, g10, g20, g30) So if you break it down to column matrix elements does it become: gamma00 = 0.5*Psi(a00_(i+1/2, j))*(g00_(i+1, j) - g00_(i, j))/alpha00_(i+1/2, j)gamma00 gamma10 = 0.5*Psi(a11_(i+1/2, j))*(g10_(i+1, j) - g10_(i, j))/alpha10_(i+1/2, j) etc... Is this correct? Thanks SHuo |
TVD scheme in unstructured finite volume discretization | abcdef123 | Main CFD Forum | 2 | January 16, 2013 00:26 |
Conservative TVD or WENO scheme? | Wen Long | Main CFD Forum | 3 | July 9, 2004 16:40 |
TVD SCHEME explanation | h.jordi | Main CFD Forum | 3 | February 28, 2002 11:58 |
level set method with TVD scheme? | zhanglei | Main CFD Forum | 1 | April 25, 2000 14:01 |
TVD scheme at low Mach number | Axel Rohde | Main CFD Forum | 5 | August 6, 1999 02:01 |
