labyrinth seal leakage anlysis using fluent4.23 -if any bench mark problems pls send it to my addres |
October 28, 1999, 06:27 |
I am finiding difficulty in labyrinth seal leakage analysis using fluent DOS version, please if any body is using fluent 4.23 for labyrinth seals, send me ur analysis report
October 28, 1999, 13:00 |
Re: labyrinth seal leakage anlysis using fluent4.23 -if any bench mark problems pls send it to my addres
(1). For us to help you, you need to state the kind of difficulties first. (2). The geometry of a labyrinth seal is very simple. And it is 2-D axisymmetric. (3). You can specify the inlet velocity as the boundary condition. That should be good enough to obtain the flow field through the labyrinth seal passage, and then you can obtain the pressure difference between the inlet and the outlet stations. (4). The only difference between 2-D and 2-D axisymmetric is that, in the labyrinth seal case, one of the walls is rotating. This could be the seal itself, or the casing, depending on the design. (5). If the difficulty is related to the use of a particular code, you will have to find the solution from the person who wrote the code first.
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
pls explian me how to simulate 2d-labyrinth seal problem using fluent4.23 | murali mohan | Main CFD Forum | 0 | October 26, 1999 01:40 |
