NO STAGNATION POINT FOR AIRFOIL SIMULATION
Old   January 29, 2008, 09:57
Default NO STAGNATION POINT FOR AIRFOIL SIMULATION
Rif
Hi, I'm running an airfoil simulation on a cfd code,SWIFT. does anybody know why i cannot get a stagnation point at the leading edge of my airfoil? The velocity at the leading edge should be 0 m/s but i cannot seem to get this in my simulations. i'm running for AOA 0 degrees at high Reynolds number. what can possibly cause my simulation to have no stagnation point at all?
Cheerios Rif
Old   January 29, 2008, 10:13
Default Re: NO STAGNATION POINT FOR AIRFOIL SIMULATION
Mani
Very weird!
Old   January 29, 2008, 13:26
ag
I would guess that the boundary conditions have either not been specified or have been specified incorrectly.
Old   January 29, 2008, 16:00
Mani
Have you specified the airfoil as wall? Again i agree with ag something is wrong with BC.
Mani
Old   January 29, 2008, 16:47
Simon
What type of mesh typology are you using. I would need to look at your mesh before i can say anything. Can you e-mail it to me on cfd.student@gmail.com.
Simon
Old   January 30, 2008, 06:42
Simon
Mesh is indeed not a very good one as you mentioned in your e-mail. However, it should still give you a stagnation point. Your boundary conditions also ok. Mind boggling
Old   February 4, 2008, 07:33
Glenn
Two thoughts for your consideration on this... 1) Are you seeing the flow vectors splitting and heading towrads the pressure and suction side of the airfoil at the leading edge? If so, stagnation falls in between this split direction vectors...but if you mesh is coarse there, you may not have any mesh points to capture the actual fidelity of a stagnation point. 2) If you do not see the vectors splitting towards the pressure and suction sides, it is possible your stagnation point exists on the airfoil pressure side, slightly downstream of the leading edge. You may be experiencing a scenario where the flow wants to head around the suction side so strongly, relative to the pressure side, that the approach flow is vectorially re-oriented towards the suction side and stagnation is occuring off the leading edge onto the pressure side.
Check your solution to see if either of these scenarios makes sense to your specific problem.
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Point the noob in the right way - IC Engine exhaust simulation AndreF OpenFOAM Running, Solving & CFD 12 December 16, 2009 05:04
Replacing mesh while running a simulation akultane CFX 1 November 15, 2009 13:46
Stagnation point and other issues Freeman FLUENT 0 December 12, 2005 15:16
How can I get Cp=1 at the stagnation point ? largeeedysimulation FLUENT 1 September 7, 2005 18:03
