Solvers for Sparse Matrices
Old   October 29, 1999, 11:45
Default Solvers for Sparse Matrices
Morvan Dominique
I am in the search of linear solvers for sparse matrices preferably coded in FORTRAN. For 2D calculations the use of the Finite Volume method results in solving pentadiagonal systems which can be solved by an TDMA algorithm (TriDiagonal Matrix Algorithm). Then I hope of better performances by using a GMRES method (with a preconditioning)? Thank you in advance.
Old   October 30, 1999, 17:49
Default Re: Solvers for Sparse Matrices
Huckleberry Finn
Check Numerical Recipes
Old   November 1, 1999, 06:38
Dr. Hrvoje Jasak
There is a book by Ferziger and Peric (Computational Methods for Fluid Dynamics), which deals with this (among others). The book also quotes a web-site with example codes you can get for free from the same authors (I guess you can find both in Frequently Asked Questions or similar).
Old   November 2, 1999, 03:37
Frank Bramkamp
Ths question was already asked a few days ago by someone else. So I can just repeat my answer again.
A good solver (in my opinion) is
http://www-fp.mcs.anl.gov/petsc/
including all kind of Krylov-subspave solvers (GMRES, BISTAB...) and Preconditioning (ILU(n)...)
It solves your equations etc.. also in parallel using MPI, if you want to do this.
A solver in Fortran is 'templates' http://www.netlib.org/linalg/html_te...Templates.html
But I heard that in the GMRES routine there was a bug, though I don't know if it was the present version.
The PETSC software can be used in combination with C and Fortran.
Frank
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 14:22
Reaction solvers megacrout OpenFOAM 5 July 8, 2011 10:54
Block matrices vs segregated solvers fisher OpenFOAM Running, Solving & CFD 9 June 13, 2010 04:15
network comms amg solvers bob Main CFD Forum 0 March 1, 2007 19:58
PHOENICS Solvers Hu Phoenics 0 June 28, 2002 07:37
