Farfield BC assignment
Old   February 4, 2008, 13:56
Default Farfield BC assignment
BM
I am simulating a self-breathing polymer electrolyte membrane fuel cell i.e. the cell is open to air and there is no forced convection. The solver (in-house code) is incompressible utilizing the SIMPLE algorithm for momentum flow field, solves the species transport and decoupled heat equation for temperature (2D). The density is coupled via ideal gas law.
The fuel cell, is internal to the domain, on one side (with the other side closure obtained by joining the farfield boundary) and hence the boundaries are treated as internal and fluxes calculated accordingly. My problem arises when I consider the farfield boundary. Note, there is no flow initially. There is a species and temperature gradient created near the fuel cell boundary due to consumption of oxygen in the air and release of heat of reaction, which causes a density gradient and hence, air flow. I use Bousinessq approximation to model this. Considering this the BC's at farfield have been set to,
P=P_inf
V=0 or dV/dn=0
Y=Y_inf
T=T_inf
These would be akin to a pressure outlet BC. However, I am having numerical problems with these BC's. The code does not crash but does not converge either. (My domain is atleast 20L in both directions and I have refined grid) I have never used farfield conditions to model coupled heat and mass transport for incompressible flows and am unable to find literature pertaining to it. I would really appreciate any hint if anyone has any suggested papers or has dealt with similar problem before. Thanks
[Gmsh] Mesh flattening and fluid assignment not possible. paka OpenFOAM Meshing & Mesh Conversion 6 April 4, 2011 08:53
Pressure farfield vs Velocity Inlet BC DarrenC FLUENT 1 September 16, 2009 02:23
farfield Vs symmetry boundary condition Rajat FLUENT 1 October 21, 2005 13:53
Farfield BC: vortex correction for lifting bodies zonexo Main CFD Forum 2 September 6, 2005 02:10
private tuition for a cfd assignment - payment ahmed Main CFD Forum 4 August 10, 2005 09:15
