Home > Forums > Software User Forums > COMSOL
convergence problem in comsol
Old   February 24, 2008, 16:54
Default convergence problem in comsol
anderson
hello, I keep getting convergence problems when doing a simulation using comsol multiphysics. It is about water flowing through an orifice. I am using a pressure driven flow and I am using "parametric solver" which increases the input pressure by 10,000 Pa (10kPa) at each step. But somehow after passing a certain limit it gives this convergence error.
I tried to increase the mesh number, and thus the degree of freedom to around 80,000. This way I was able go get better results. I mean the convergence limit moved to higher pressure input values. But still I get no result for pressure higher than 400,000Pa (400kPa). And my computer is not able to handle problems more than 100,000 degrees of freedom.
Is there any other way to overcome this problem? Is it possible that I am doing something wrong?
Convergence problem and the Mach problem in supersonic model ranxiaoran FLUENT 2 July 28, 2021 12:27
Rotate frame reference convergence problem! wjy-c CFX 2 September 26, 2014 06:03
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 10:47
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
