modeling of a bulk heater
Old   March 12, 2008, 10:32
Default modeling of a bulk heater
Mahmoud
Dear all. nowadays I control a temperature of a heater, the heater is consisting of a Bulk Aluminium and at its bottom there is the Coil Heater. When I apply the current to the Coil heater the temperature begins increasing when the power is switched of the temperature continue increasing till it reaches a maxima. then temperature decreases, while it decreases if the power is switched again it continu decreasing till reach a minima. and so on. Is this a form of inertia in the heater? I have developped many PID controllers that control Motor Speed, Flow, Pressure using MATLAB and VISSIM, i did that because i was knowing the modeling ( Transfer Function ) of the system i want to control, but now I could n't do that because i do n't know the Transfer Function of such heater...
How to model this heater?
Is there any way to model it?
Plz guide me in my PROBLEM.
thanx in advance.. M.Shendy
plot bulk temperature of fluid mohammadkm FLUENT 4 December 13, 2011 15:37
Reversed flow error with thin film heater MK FLUENT 1 February 12, 2009 10:26
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 11:48
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 14:49
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 09:21
