Home > Forums > Software User Forums > COMSOL
error in COMSOL:'ERROR:6164 Duplicate Variable'
Old   May 26, 2008, 16:34
Default error in COMSOL:'ERROR:6164 Duplicate Variable'
bhushas
I am working on a model which has 'level set 2 phase flow --> chemical engineering module' and 'Axial symmetry, stress-strain with fluid interaction --> fluid structure interaction --> structural mechanics module'. basically i have a model in which there are 2 fluids of different density and low density fluid is at bottom initially. as it moves up, it will exert force on a flexible cantilever beam attached in midway. i am finding the effect on that beam including displacement and stresses. i am having following error 'ERROR : 6164' and following detail message. ***********************************************
Exception:
com.femlab.jni.FlNativeException: Duplicate variable name Messages:
- Variable: r
- Variable: rTIME
- Variable: z
- Variable: zTIME
- Variable: r
- Variable: rTIME
- Variable: z
- Variable: zTIME
- Variable: r
- Variable: rTIME
- Variable: rr2
- Variable: rz2
- Variable: z
- Variable: zTIME
- Variable: zr2
- Variable: zz2
Stack trace:
at xmodel.cpp, row 840, ()
at com.femlab.xmesh.Xmesh.meshExtend(Native Method)
at com.femlab.xmesh.Xmesh.meshExtend(Unknown Source)
at com.femlab.xmesh.MeshExtendRunnable.run(Unknown Source)
at com.femlab.server.FlRunner.run(Unknown Source)
at com.femlab.util.ad.run(Unknown Source)
can anyone please show me what can i do in this situation?
Old   May 30, 2008, 04:35
Default Re: error in COMSOL:'ERROR:6164 Duplicate Variable
Magnus Ringh
The explanation of this error message in the Diagnostics section of the COMSOL documentation says:
A variable name has two different definitions. For instance, the same variable name appears two or more times for a dependent variable, a constant, an expression variable, or a coupling variable. Remove or rename one of the variables.
In your case, you are combining two in themselves rather advanced interfaces: the level-set two-phase flow interface and an FSI coupled multiphysics interface. The FSI coupling includes an ALE application mode that provides a moving mesh, so there are two different "frames" in the model, as well as two different application modes for the fluid flow.
It might be a good idea to first solve a simpler case and then add more physics incrementally.
You can also contact the COMSOL support staff at www.comsol.com/support or support@comsol.com
Hope this helps,
Magnus Ringh COMSOL
OpenFoam-1.6-ext Allwmake compilation error - one last barrier Pat84 OpenFOAM Installation 15 July 25, 2012 21:49
Condensation as an additional variable Clark Griswold CFX 2 April 21, 2012 07:20
Embed explicitSetValue in chtMultiRegionFoam samiam1000 OpenFOAM 2 April 18, 2012 05:14
Instalation on ubuntu 710 basilwatson OpenFOAM Installation 17 March 16, 2012 20:16
variable viscosity -NOT! George Bergantz Main CFD Forum 15 September 19, 2000 14:28
